Bigstuff95
- Joined
- Aug 5, 2018
- Messages
- 4
I'm wondering about Grounding?, you can use a grounding strap or a copper grounding strap, or just regular neg. side power wire, can regular power wire work or do I have to get a grounding strap to ground my Cb.? or to ground both my mobel Cb. and my Base Cb.?, does it have to be a grounding strap in order to properly ground your Cb.? is a grounding strap for the antenna only? I know they use them on grounding body's to the frame on trucks as I've Sean one on my pick-up bed, I understand that its all about the grounding on Cb's, grounding both the Cb. and antenna, I'm just not sure about the grounding straps? as I've never used one before?
