So let me see if i can type this up so it makes sense.
i use the database option to preload the stuff i want hear on my BCD396XT. the issue i am having is figuring out how groups work I will explain how iw ant to use this scanner which i believe is possible. with BC780XLT that used banks starting with bank 1 i would add CHP frequencies about 10 channels. than bank 2 would be local sheriff stuff that was about 8 frequencies and so forth each bank was programmed that way so for example i did not want to listen to CHP or i did not want to listen to SHERIFF i would turn off the bank by pressing the number on the keypad of the scanner. well am i able to set my scanner up this way? as i did with the 780xlt ? so far i have group 1 with FIRE, SHERIFF, LOCAL PD all in one and i do not like that because sometimes i just want to hear FIRE or LOCAL POLICE. so if someone could somewhat explain what i need to do here that would be really awesome.
