GTAA Fire Dept.
Doug093
Beamsville, Ontario
Hello everyone, just wonder if anyone knows exactly what frequency's Pearson Int.'s fire deptartment uses? I checked the database here with no luck, on Canairradio.com they list a few things, they have this "Airport Operations Control Centre (AOCC) & Emergency Services - (Region of Peel trunked radio system)" and "122.675 Emergency Services - Pilot to Fire Vehicle communications". Unfortunetly I'm not close enough to Person to just plug these in and try them, so if anyone knows for sure on what frequency they recieve their calls on let me know!
Thanks in advance,
Doug
GTAA Fire is on the Peel Region Motorola trunked system - check the Pearson International Airport Talkgroups section for the talkgroups used by fire.
http://www.radioreference.com/modules.php?name=TRSDB&sid=1573
For joint calls with MFES you will also hear Red Command on the assigned Mississauga Fire tg.
You may also hear units communicating with the control tower on conventional frequencies - unfortunately someone else will have to help with the exact ones to monitor.
