gtx..r55..issue..HELP!!!
gmee
i having problem with motorola gtx...it was trunking radio and already got program on this radios...i got cable and software...when try to read it write.. R55...try another radio and diffrent software same problem...for motorola radio i knew that i should read the radio first before i can working on it...for information i used disket and run on dos ...try doing this for such long time...any suggestion or information ...please help !!
WX9EMS
Under the Cheddar Curtain
That "r55" you are seeing is actually RSS, meaning the PC is trying to communicate with the radio. What version RSS are you using? PC? RIB/Cable? Yes you definitely need to archive your code plug before doing anything to the radio, just in case. If it does not read the radio, you either have a software issue, RIB/cable issue, or a PC issue. Not sure what the latest version of RSS for GTX is, but R04.00.00 isn't backwards compatible. I assume that you are booting from DOS and not running in a DOS window, RSS requires a pure DOS environment.
gmee
gtx issue r55..HELP!!!
yes...im seeing "r55" on the radio display when try to read...but it dosent goes to program....can`t read...sometime...software not support by this software apear...try another software also can`t read..when try.. comm test..Comunication OK...i knew that
if this radio been program by vR02.00.02...i must use latest software than that to read radio...try rvn4150 vR04.00.00b...also r55...for information im using win 98 and win xp pc...rib cable from ebay..try program gp 300..gp328..motorola pro5350/7350..with No Problem...OK...im booting pure Dos...help..
WX9EMS
Model number of your GTX. Do you mean radio not supported by software instead of software not support by this software? If you are getting a model mismatch, need to verify it is a GTX and not something similar like a LCS. and be certain you have corresponding RSS. By checking other radios verifies PC and RIB. Have you been able to read this radio before? Do you have another mobile radio to try and read? Do you have an actual RIB box or a RIB-less cable? I have heard some people having problems with rib-less cables. With my Toshiba Pentium II laptop, GTX RSS takes a few more minutes to contemplate life.
gmee
Help!!!
thank..
My GTX num..AZP0511S05NIAA...tanapa PMUF1021B...and AZP05VJH25N1AA..tanapa PMUF1001A .and 4 more gtx radios.. try to read .r55..display on radio...using GTX V.R02.00.02 GTX/MAX638 TRUNK RADIO GTX RVN4150 V.R0303.00B GTX/MAX638 RVN4150 V.R04.00.00B GTX RESTRICTED TO FTR V.R01.01.00 GTX/MAX638 TRUNK RADIO V.R01.01.00....serial bus error...or.. radio not support by this software..I Never read this radio before..got actual RIb BOx for rss from ebay...try another radio same issue....
Try open the caseing
there is what they call Logic Board inside the radio...got six pin ...should i put a jumper on it. .when try to read or programming???..maybe this radio been program by latest software than i got...what is the latest software for GTX?..if u got can u please sent it to me...Or it must use hexeditor or crack software to program this radio?..
Any idea....please help me...
WX9EMS
The numbers listed above mean little to me. I need model a number; should start like M11 for mobile and H11 for hand held. Worst case send a picture of the sticker.
gmee
GTX issue r55..HELP!!!
sorry..
model H11UCD6CU1AN......any idea or tips to configure..plzz..
WX9EMS
Well, after doing some reading...I am unsure what is happening. RVN-4150 should work with your portable, why it isn't, I do not know. Could be hardware, software, or something else. I am not familiar with GTX portables. If I had it in front of me, I could figure it out, but it isn't. Best advise is to find someone near you to have a look at it. If you have a different PC, try that.
talviar
Uniontown, PA
That model comes up as an LTR portable. From what I remember there are two variants on GTX Software, one for LTR, one for privacy plus. If you don't have the right one, the radio will start to read but won't do anything and error out. . . . .
As always, this has been my $2.25 and YMMV!
73,
Tony
WX9EMS
In your GTX RSS folder, there should be a readme.txt file. Inside that should see something like this...
The Motorola GTX Radio Service Software (RSS) for Privacy Plus / LTR
currently supports these Models:
10 Trunk Systems x 8 Groups/Sys (80 Trunked Modes), 10 Conv. Channels.
"Standard" Full-Feature Models; Portables have Keypad -and- Display.
M11UGD6CB1_N - GTX MOBILE, 800 MHz, 15 Watt, Privacy Plus.
M11WGD4CB1_N - GTX MOBILE, 900 MHz, 12 Watt, Privacy Plus.
H11UCD6CB1_N - GTX PORTABLE, 800 MHz, 3 Watt, Privacy Plus.
H11WCD4CB1_N - GTX PORTABLE, 900 MHz, 3 Watt, Privacy Plus.
M11UGD6CU1_N - GTX MOBILE, 800 MHz, 15 Watt, LTR.
M11WGD4CU1_N - GTX MOBILE, 900 MHz. 12 Watt, LTR.
H11UCD6CU1_N - GTX PORTABLE, 800 MHz, 3 Watt, LTR.
H11WCD4CU1_N - GTX PORTABLE, 900 MHz, 3 Watt, LTR.
"Standard" Full-Feature "High-Power" MOBILES:
M11UGJ6CB1_N - GTX MOBILE, 800 MHz, 35 Watt, Privacy Plus.
M11WGJ4CB1_N - GTX MOBILE, 900 MHz, 30 Watt, Privacy Plus.
M11UGJ6CU1_N - GTX MOBILE, 800 MHz, 35 Watt, LTR.
M11WGJ4CU1_N - GTX MOBILE, 900 MHz, 30 Watt, LTR.
4 Trunk Systems x 3 Groups/Sys (12 Trunked Modes), 4 Conv. Channels.
"BASIC" Models; Portables have -NO- Keypad, -NO- Display.
H11UCC6DB1_N - GTX PORTABLE, 800 MHz, 3 Watt, Privacy Plus.
H11WCC4DB1_N - GTX PORTABLE, 900 MHz, 3 Watt, Privacy Plus.
H11UCC6DU1_N - GTX PORTABLE, 800 MHz, 3 Watt, LTR.
H11WCC4DU1_N - GTX PORTABLE, 900 MHz, 3 Watt, LTR.
Now check your readme file and see if your model is in there. It is listed in my file, but if it isn't in yours, you do not have the right software. Post a picture of your programming setup, RIB and cable.
