H38 option and more then 48 CH in MTX2000 with no KBD ?
ronenp
Hello
Can someone explain me what is the H38 Option that apear in the
MTS2000 ?
I try to look in the CodePlug and didnt recognise something special
2) is there any way of operatiing more then 48 Channels into mtx838
or mts2000 with top display and no keyboard ?
Thanks Forward
Ronen
fineshot1
NJ USA (Republic of NJ)
Hello
MTS2000 ?
Thanks Forward
Ronen
1 - H38 option is SmartZone
2 - No, 48 is max
ronenp
Intresting ...
I have one radio that have smartzone (in the trunking system option) but when i look at the radio info in the software there is no h38 and another radio that have also smartzone and there is a h38 option mentioned while i do radio history (it is f9 after reading the radio)
so how can it be ? and whats the diffrence ?
fineshot1
Intresting ...
sorry - all i can tell you is that H37 is smartnet and H38 is smartzone. its possible that they are not listed the same across different radio platforms and you did not mention exactly what radio listed what options once you read it with rss so not sure how to answer your question.
ronenp
Thanks anyway for the quick response
i realy apreciate it ....
Best Regards
Ronen
BigLebowski
Piedmont NC
I had a Top Display MTS2000 that did 255 channels. So it is possible, you'll just have to find the right files to make it work.
gatekeep
FAIL 01/93
New York, NY
Continuous rotary? Sounds very MTX'ish. Only, because, I've never seen an MTS2000 continuous rotary.
ronenp
My radio is also have a Continuous rotary and a top display (no keyboard) mtx8000
I had put two codeplug in it one 99 CH and other 160 CH and both didnt worked out ....
every time that CH 16 passed it jumped back to CH 1 there was no option to get more then 16CH no matter what i did
so i could have only 3 Zones of 16 CH each ....
are you sure that your radio gave you more then 16 CH with the switch and didnt roll back to ch 1 after the 16th CH ? and had no keyboard at all ?
if the answer yes ... is there anyone that have such codeplug ? (800MHZ SmartZone top display more then 48CH) ?
Thanks Forward
Ronen
