465,MFR465 said:Justin,
, however the dispatch on 154.3850 is simulcasted on 453.5625 from headquarters and the UHF is on a stand-alone basis.
how do you input 7.5 hz in the scannerjaymatt1978 said:Hackensack will STILL be dispatched on 154.3850 the new UHF and 7.5 Hz split frequencies are for fireground purposes only.
You have to have a scanner that is capable of doing the step size. The Uniden 780XLT will do it and pretty much all newer scanners. If you have an old scanner and you want to listen to the Hackensack fireground 3 frequency 151.4225 PL 100.0 you would enter 151.4250, even though its not exactly on frequency most scanners will not have a problem tuning it in. You may have some audio degradation because its most likely in narrowband.lawfirealarm said:how do you input 7.5 hz in the scanner
