hackrf /portapack
home121
Florida
Every thing went good downloads, portapack tool, firmware, the mayhem sd_card loaded perfect. Did the DFU went fine 100 %, But putor does not
see device. Can't find Libraries for HRF1 and w/o that nothing works. I bought a 32 Ghz SD Card formatted it w/ Fat32 for portapack.
This SDR HRF1 is becoming what we call diminishing returns. Spent a lot of money and more important time. Also mayhem.bat no where to be found. Any idea's Welcome ?
Markb
Planet Earth
I think you have to use Zadig to change the drivers if you haven't already done that. It's been a while since I had to do that part.
There are 2 separate folders that have to be downloaded. One has all of the files for the card and the other one is the actual firmware entitled mayhem_v1.1.1_FIRMWARE
Flash_portapack_mayhem.bat is located in this folder.
home121
Florida
Tnk's Markb ; I did exactly as written, watched many video's downloaded mayhem _v1.1.1_ Did not say Firmware said SD Card, D.L. portapack tool ect. put new 32 Ghz. SD Card in, formatted it. I'm sure its something i'm doing wrong, like I said I am no computer wiz. Tnk's again joe
home121
Florida
When I go to flash either hackrf or portapack I get not found, for both. It says to put portapack in hackrf mode The screen never lights up, so how can I put it in hackrf mode ?
Markb
Planet Earth
Have you tried a DFU reset? Hold the DFU button down while unplugging the power and continuing to hold the button while plugging it back in.
home121
Florida
No but I did hold down the dfu button and set button then released the set then dfu. What I got was Determining device status: = dfuIDLE, status= 0 dfu, continuing. DFU mode deviceDFU version 0100. Device returned transfer size 2048. copying data from P.C.to DFU device. Download 100 % 2206 bytes. Download Done. unable to read dfu status after completion. can,t detatch resetting USB to switch back to run tie mode.
home121
Florida
Also said cant match ?
home121
Florida
If we could figure out how to get Portapack screen on, maybe I could put it in hackrf mode that it keeps asking me to do before I flash either hrf1 or portapack. To turn it on is the center button on portapack right ? Unless there is another way to turn it on, I know it sounds stupid, but center button seems logical as to turn it on, maybe if I throw it against the wall it will turn on ?
home121
Florida
Hey I remember reading that if you don't have the libraries on the hrf1 it will not do anything, I don't remember seeing anything to do with libraries. Don't know if it runs in the background or what, and I appreciate the time and effort to help out another one interested in spectrum analysist above 2 Ghz. Btw I've been using hrf1 w/ HDSDR so i know it works, just can't get it to hook up with PortaPack yet. Tnk's again Joe
ciscovk
Hello everyone,
Does anyone know how to convert RAW .wav file to .c16 (suitable for havoc-portapack format)?
