reconrider8
ok how do you understand what they are saying all i here on here is distant voices i guess this is how you learn
thanksI've quickly taken almost all the freqs in the wiki below 12 mhz or so (since that's all that will propagate now...) and put them into a spreadsheet. There is also a .320 file for RX320 users that use the Scan320 program. I did this rather fast, so it's likely there may be errors. I noticed that the ALE Ham stuff is mostly on USB - on 75m, hams are usually on LSB, but I think that ALE users use USB deliberately to avoid interference.
If you are using a control program with your HF radio - many I know do, when they have numerous freqs to check - some have the ability to import .csv files. The spreadsheet is there to explain the various fields - you can change that to a .csv file in Excel pretty easily, and I would imagine there are a few other spreadsheet programs (Open Office comes to mind) that can also do it. You will, of course, need WinZip or similar to pull the zip file apart.
If you're using Callsign, RxPlus, DXtra, Ergo, HRD or any of the others, this should make things a little easier for you....73 Mike
all i really want is just clear audio from down that way so if anyone can get a clear stream pls post
ive never really messed with hf so yea why i said im learning a lil more and more
it takes some getting used to.if your on my feed uscg point reves is comming in as strong as camslat chessapeke.but i cant hear either resq c130 up at the north pole 1701 1711
