Halton edacs, which one?
johndh
radio referance says System Type: EDACS Networked Standard for Halton.My 246t has three different edac systems to choose from narrow, wide and S.C.A.T. which one do I use for their system?
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Easiest thing to do is to program in the system 3 times using each type then see what works.
However, to save you a few minutes, try Wide.
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
IIRC I picked this one up when I hung out in Pearson for a few hours the other day. I seem to recall it was EDACS Wide (which is 'standard').
SCAT/SCT is a Single Channel (Autonomous) Trunking system, i.e. one frequency only.
Mike, do you know if a "narrow" system sounds any different, or is it just dependent on frequency allocation (narrow banding)?
mikewazowski
Staff member
Forums Manager
Oot and Aboot
From what I remember, EDACS narrow is a 4800 baud control channel vs a 9600 baud control channel for wide.
I believe that 900Mhz was always narrowband so 4800baud is more prevalent there. I'm guessing the 9600baud control channel format wouldn't fit in the required bandwidth.
Hence, the voice channels on a 4800baud system are probably narrowband as well.
DaveH
Ottawa, Ont.
Any system on 850MHz is assured to be wide (regular) EDACS. Narrow is 4.8k
versus 9.6k and sounds different thought I've never heard a narrow system
myself (they are said to exist on 900MHz due to bandwidth limitations).
Check out the two diifferent sounds here:
http://www.kb9ukd.com/digital/
Dave
