Dwitherspoon
- Joined
- Dec 27, 2020
- Messages
- 64
I stand by all my statements. What you are doing is not "working". The so called ground plane you think you are attaching to a CB antenna is not doing much of anything and your coax from the antenna to the radio is the major counterpoise for the antenna. RF currents are flowing all over the outside of your coax but the pie tin is way too small for any amount of current to flow and cancel radiation. Instead you have a goofy offset dipole consisting of the exposed antenna as the hot side and your random length of coax as the other side of the dipole. Your coax is probably radiating as much as the whip and a proper size ground plane will not radiate.
It works just fine on CB. It doesn’t work on ham. In my experience as watts increase, the ground plane needs to as well. In CB extra watts, even with an amp are less demanding than 10 meter. My 94hp is pushing 200 watts on ssb at 25 amps. It’s killing my ground. I added a 15 ft RG 58 instead of my 1 FT jumper and the problem resolved on my 18” disc. My ground isn’t large enough. Kids, if you want to defeat high SWR in a pinch, add cable length to bleed off power.
