n4voxgill said:
the best bargain today is a Icom IC-T2H that is a 2 meter 5 watt handheld. Uses 8 AA batteries can be NIMH, Nicad or even alkalines. Less than one hundred dollars. Plenty of capacty and can be programed with a computer. I bought mine from
www.gigaparts.com
This is great as I have a bunch of AA NIMH 2500 ma batteries and they last a long time even when transmitting. I use the new MAHA battery charger that charges one to eight batteries at a time..
I have several dual band radios, and frankly hardly ever use 440 MHz.
I've never heard of an open 440 repeater in New Braunfels area - is there one? I used to live in Seguin, and yes - just about all the ham activity is VHF there.
OKC is a different story. There are quite a few VHF repeaters, and quite a few UHF ones also. I think it has some of the best repeater locations around this area. There are several that I know of that have RX/TX antennae >1000' AGL! (ours was like 200' in Seguin - 146.76). Needless to say, a VHF/UHF dual-bander would serve you well. In addition to using it for ham, you can listen to public safety stuff on it also. VHF will let you listen to OCPD (for the time being), Nichols Hills, Moore, and a few others; while UHF will allow you to listen to the SO, The Village, Warr Acres, Bethany, Midwest City, etc...
Sounds like the HT will get you started. It is a little complicated at first, but the VX-7R has everything! I usually hang out on 444.775 + 107.2 (KK5FM)
I would think the 7800 would do you well. Try reading some reviews on
www.eham.net before you finalize your decision!
