jparks29
John McClane
Well....
In trying to keep my installs low profile.... I've come into a dilemma.
Vehicle is a 2004 F150. Mounting location is passenger side fender where existing FM antenna is, I'll be removing the antenna and modifying the existing mount for either SO-239 or 3/8x24 (NMO is too large to fit on mount area)
I already have a Phantom Elite center of the roof for APRS, which is all but invisible from the street, and a 'sat/onstar' look-alike on the roof for GPS/800.
Currently I'm running a 1/4 wave whip center of roof for VHF temporarily with UHF not being hooked up, but that will be replaced with the Phantom Elite when I get my dual band antenna setup.
I have a few options.... None of which are good...
1. Go with a Sti-co disguise antenna. 500$ - ****ty output - Looks EXACTLY like the factory antenna.
2. Go with 3/8x24 mount , replacing the factory FM mount/whip with 3/8x24 and 19" dual band antenna and center load 'loose wound' coil. First problem is 1/4 wave on VHF and 5/8 over 5/8 on UHF, which leads to problems because there is very little groundplane (being mounted on the edge of the truck), ~50$ - looks aftermarket but not enough to raise eyebrows - Good tx/rx but not great because of lack of groundplane.
3. Go with SO239 mount and an antenna like the Comet SBB5 which is 1/2 wave on 2m (which reduces/eliminates the need for a groundplane). Also replacing factory fm ant mounting hole. OBVIOUSLY aftermarket, and @ 39" and a wide base DEFINITELY something that would be questioned. About 60$, best TX, highest profile.
4. so239 mount fiberglass whip, dual band, looks like .. well.. a fiberglass whip.... definitely thicker, but could be played off as being factory... since the factory fm antenna mount has a shroud which encloses the base, meaning just the antenna would stick out, making it look somewhat factory. ~40$ ... ...presumably 1/2 wave on VHF because of 2.5db gain (stated), so similar in performance to #3 (theoretically)
Thoughts?
BTW. Here's a pic of the truck to get an idea.
Single CH, dual band Orion setup..
In the middle of the install, still finishing things up....
Thoughts?
