Hamilton Co APCO 25 Sound Quality
WM8L
Miamisburg, OH
Is anyone using BC296D on Hamilton Co. and getting good reception?
I get below average reception quality with a lower setting of 333. It seems to be very sensitive adjustment. If I use this setting and turn the squelch down I can receive with poor quality.
This is my first experience with digital scanning and any help would be great.
The BC296D is fantastic on everything else. I am sure it's probably operator trouble.
Terry
scannerfreak
Well Known Member
Indiana
I have noticed that with the HAMCO C-QPSK system you have to be relativley close to a tower. I live about 15 to 20 miles from the closet tower(Colerain) and get garbled 25% of the time. If I drive to Colerain I can sit in the parking lot of the Northgate Mall and it works flawlessly. I can use the default setting and get good audio
Maybe because they simulcast on a bunch of towers the towers don't have to have a big audio output. At least, That's what I'm beginning to think. I'm going to get me a yagi and point it in the direction of Colerain and see if I get better reception.
wolverine
Cincinnati, Ohio
Im going to be getting a Uniden BC296D to monitor Hamilton County but i also want to monitor Clermount county and was wondering if you or anyone has used the BC296D to monitor Clermount county and if so, how does it work on the system. Thanks.
scannerfreak
Well Known Member
Indiana
It works great on Clermont, was there last week logging TG's.
jpm
I'm glad someone finally understands the point I'm trying to make with distance on these digital systems. I'm lucky because the tower I monitor is 1/2 mile away. I notice the audio issue when theres one or no strength signal bars.
WM8L
Miamisburg, OH
My biggest problem was seeing the scanner stop on Valid ID's and nothing was being heard. I am in the Sharonville area and I can not hear at any setting unless I lock out any other banks that is not trunked and turn the squelch all the way down and adjust the audio quality. The first time I saw this I thought something was wrong with my scanner.
Not sure where the nearest tower is in the Sharon Rd Mosteller Road area but it must not be very close.
I am going to drive over to Clermont County real soon and try it out over there.
scannerfreak
Well Known Member
Indiana
I can get a full 4 or 5 bars on my scanner at home, but still get garbled audio. When I drive to colerain, I can hear it fine with the same 4 or 5 bars. That's the part I don't get. Now, I can monitor an APCO 25 3600 system and the tower is exactly 44 miles away from me and it decodes the digital perfectly. Go Figure.
542907
Try setting the control channel to FM instead of the default NFM.
I did this today and it seems to really help the audio.
This has helped many going all the way back to the BC 780.
I had garbled audio on full scale signals before.
It's time to stop making scanners that include everything and concentrate on digital
Scanners for aircraft, cb and all that other stuff can be had for ever for 50 bucks.
Good luck!
542907
Good luck!
firemedic2150
Senior Member
Right here...
I know that you guys are talking about Hamilton County OH, but just for information Hamilton County TN is going digital, so you might get some confusing discussions going on.
Mark Mc.
