Hamilton HSR - DMR Tier 3 - Uniden 325P2 issues
newatthis
Toronto Ontario
Thanks for trying. I would have the same request for 996P2. With Uniden focused on selling their new radios I fear our hopes for that could be dim.
newatthis
Toronto Ontario
One thing that might help determine what it was we are acting for. Could some one with DSD let us know if it is a RAS system like Mobile Business in Toronto?
I can hear other Toronto TierIII but this one with RAS will not work on 996P2 and I have tried multiple lcn orders based on DSD and Radio Refernece to no avail. Sit on a channel it decodes but it does not trunk track this while BCD436 does with no problem. RAS is listed on the last 996P2 firmware so should work
ATCTech
As reported by DSD+ on 411.6375 moments ago:
newatthis
Toronto Ontario
Thanks. That settles it. The 996P2 and 325P2 are not tracking systems using RAS even though firmware updates clearly indicate the should. The HSR and Toronto's Mobile Business TIII are both RAS systems and both demonstrate the exact same issues
mapleradio
Has Uniden responded to anyone else with any firmware that tries to deal with RAS in a better semblance of order?
Thank you :)
Forts
Ontario, Canada
Capacity Max systems have RAS enabled by default out of the box. I had a system local to me and I saw the exact same issue.... 325P2 refused to play nice with it. My SDS100 has no issues...
mapleradio
I wish they would fix the 325P2 or the 436HP. It's too expensive to keep buying new hardware all the time when they have a faulty implementation to begin with!
mciupa
Canadian DB Admin
Moderator
mapleradio, on your BCD436HP:
Run Analyze, LCN Finder, does you scanner find the same LCN's as what is listed in the database?
If the database is incorrect, please advise so we can fix it ASAP.
mapleradio
It looks like all the LCNs are the same. It still won't track the trunk however. Could it also be a simulcast type setup?
mapleradio
It will never track until you have the LCN's correct
When I utilize DSD and The 325P2, it's the same LCN's. It has RAS enabled, which according to others in this thread is what's killing it. If I park on one of the audio channels, I can hear both time slots without issue. But letting the scanner "scan" results in absolutely nothing by deceased batteries.
mciupa
Canadian DB Admin
Moderator
Did the 436 find these Channel ID's in the Analyze setting to find LCN's?
1022 - 410.7875---- 0
1046 - 411.0875---- 0
1082 - 411.5375 ----0
1090 - 411.6375 cc -0
mapleradio
I am sorry, I misunderstood the difference between LCN and Channels... I assumed we would be looking for the frequencies...
As for the 436... I don't have the DMR upgrade on it since it returned from Uniden Repair... and I just don't want to spend the money again for a new key as the serial number has changed.
Can I do that with the 325P2?
mapleradio
UPMAN fixed my DMR Key issue :) I am very appreciative!
When I did the LCN Finder, this is what was saved...
1022 - 410.7875---- CC 0
1046 - 411.0875---- CC 0
1082 - 411.5375 ----CC 0
5 - 411.6375 cc - CC 0
It now is scanning as DT3/CON at the bottom... Will wait to see if any audio.
Thank you!
