Hand held charging with a timer
W4KRR
Coconut Creek
Anyone have any first hand experience with hand held battery charging using timers to stop the charge after a set period?
Will leaving the factory supplied wall wart charger connected to a hand held scanner cause any detrimental effect if no power is applied to the wall wart? Will this cause the batteries to discharge back into the wall wart?
I was thinking about the possibility of using a timer to cut the power to the wall wart charger after like 24 hours so the batteries would not overcharge. But years ago I remember reading that leaving a wall wart charger with no power applied plugged into a scanner would kill the batteries quickly.
K5MAR
Stillwater, OK
Do it all the time. I have one of those timers that uses the little plugin dongles to turn the timer on and off, so I use just the off dongle. Set the timer at 12, and put the dongle in for however many hours of charge is recommended. But I do unplug the scanner as soon as possible after the timer has shut off. I've been doing this for 4-5 years at least without any detectable problems. Sure beats risking overchargeing the batteries and ruining them.
Mark S.
brwkem
Battery recs
What charger and battery models do you reccomend?
thx
JnglMassiv
Chicago / 016
Hmm..I'll often leave mine (BC245xlt) plugged in for a week at a time with no ill effects. I've always assumed that the charging circuit cuts off at around 5 volts or so, preventing any overcharging and keeping the batteries peaked.
And since I installed higher power NiHM cells (2300mAh), it would need longer than 24 hours in even the best of circumstances.
Assuming 100% charging efficiency and nominal specs, the radio, providing 80mA of charge current, will charge in:
2300mAh / 80mA = 28.75hours!
And this incorrectly assumes 100% of that 80mA goes to charging the cells.
K5MAR
Stillwater, OK
I don't have any battery packs that large, so using the timer isn't a problem. The BC245 manual says to disconnect the ac adapter when charging is complete. It doesn't say anything about a maint. charge. You may be right, then again you may just be lucky! :lol:
Mark S.
