handcuff question
landonjensen
Area C
hello
i was looking through a police company that sells police equipment, and i saw a pair of handcuffs that are colored red or yellow?
what is the use of them being that color? and also what are the disadvantages/ advantages between hinged cuffs, and chain cuffs?
thnks
car2back
Tulsa, OK
our county jail uses orange & yellow cuffs so as not to confuse them with the officers' sets.
newbie
St Clair, Michigan
HInged cuffs hold the arms closer together. They also dont twist one end around so you know you have them both facing the same way for that click click both arms are now locked.
You see with both types you just grab the middle and push one side then the other for a real quick lock up. Most trouble (resists) will start with the first arm being cuffed. Thats when the oh **** I am going to jail hits. With holding them that way and a little practice you can get both arms cuffed real fast.
kd5bff
Bowling Green, KY
Handcuffs
Another difference with hinged and chained is that it makes it harder for suspects to uncuff themselves. Check you local policy because I have seen agencies that do not allow hinged cuffs. I have a pair of peerless chain cuffs that I have had for years, but I prefer the hinged. Hope this helps.
Chris
n0doz
Metro PHX AZ
It's nearly impossible for a suspect to step thru hinged cuffs unless they pop a shoulder out of joint.
Dubbin
Findlay Ohio
Umm is it the hinged or chained that makes it harder? :wink:
poltergeisty
Truth is a force of nature
RLG, Fly heading 053, intercept 315 DVV
I think by far the best restraint would have to be the dreaded Chinese finger trap.
If you have ever used one of these :lol: trust me there a stinker.:)
I would actually would prefer to use the so called high security cuffs. These are hinged and instead of a standard warded type mechanism there a pin tumbler. Much like a lock in a door knob accept this is just the plug part that resides above the cuff. All personal preference I believe.
Hand cuffs are also black.
cristisphoto
LOL
Hey what is life with out the fun side...
I say combine the dark with the Lighter and MMMM
YA know what I'm saying lol
Buy seriously though does anyone in the Public Safety Community use Thumb cuufs???
Crista
cristisphoto
I would think for transport
BUt then it can cause Physical harm the Datainee or aresttee.
Hence lawsuits..
Now I think
NOT KNOW LOL
that it would be inpractical in the streets as often you have to subdues the detainee or aresttee..
your not gonna have the time or option to throw on all kinds of cuffs at first..
Tha why they have this "trick", where you have you "normal", "bent in
so ya can slap it on the wrist and it slam it closed then you just tighten or loose..
Undersatnd???
anyways, LOL
I have Never Seen any one use these thumb cufs
but they are still around leading me to belive that Someone uses them for Something
Crista
Stephen
Dallas, TX
I know in the Department that I work for we just got told that only Hinged Cuffs are to be used on subjects.
Signal3and2
Iowa
The only thing I don't like about hinged cuffs is that, if in the heat of the moment you accidently put them on upside down with the keyholes facing the ground, since they are so hard to maneuver they can be a Bey0tch to get to the keyholes. I THINK that ASP makes a pair of their double keyway cuffs with hinges instead of chains, but I don't remember where I saw them for sale.
