handheld scanner best range
Warzardo
Alberta,Canada
I live 35miles from the nearest town and i wanna pick up the police and fire bands. i was wondering what handheld scanner has the best range.
Thanks...
jonny290
Denver, CO
Well, I've picked up the FM satellites outside on a rubber duck, so I reckon my 396t 'has a range' of about 600-700 miles ;)
fineshot1
NJ USA (Republic of NJ)
Thanks...
This question gets asked on RR almost at least once a week.
Scanners do not have receive range per say.
The transmitters they receive are what has range. The many variables associated
with transmitters and the surrounding terrain and the many variables also to do with
the receiver(scanner) location and such all combine to determine receive range of a
scanner. So without more info on all of your conditions its almost impossible for
anyone to accurately or even winging it to answer your question.
ridgescan
San Francisco, Ca.
I have 3 scanners in use; my bc785d and bc350a base scanners are running off a d130j discone on the roof. The 785d suffers front end noise but gets uhf at the 40 mile mark barely fairly, the 350a gets the uhf 40 mile mark better and more copyable. The 3rd scanner, a Realistic Pro-62 handheld, gets the uhf 40 mile mark as well as the 350a with base antenna, and does it with the dukkie indoors..even better if I place it in the kitchen by the window, which tells you a lot about the radio's position indoors. This is a well made little radio. It is older technology and built to an older standard, but I advise you check into Radio Shack's handhelds. Hopefully they still maintain that standard. I hope owners of the newer generation ones chime in here.
Ed_Seedhouse
Victoria B.C. Canada
If all the stuff you want to listen to is in one general direction and you are using the scanner mostly at home, a Yagi on the roof pointing toward the signals you want might do the trick best. There is no magic scanner that will give you immensely more range than the others. And of course, the more sensitive the scanner is, the more easily will it's front end get overloaded by stronger signals.
reedeb
Dallas Texas
A simple radio shack scanner antenna about 10 ton 20 ft in the air above your house will work very well. You need nothing fancy. I used one in Maine about 50 miles from Portland and could hear em loud and clear [till they went 800]. Times I could here into Boston late at night when closer units quieted down [roughly 75 or so miles]
