n5ims
- Joined
- Jul 25, 2004
- Messages
- 3,993
Both the Pro-106 (GRE PSR-500) and Pro-197 (GRE PSR-600) are the same radio inside, just mounted in different cases. Unless you're planning to use the portable functionality of the Pro-106 I'd recommend the Pro-197. The 197 is specifically made to be set in place and used so the connections are in the back (except for the headphone and programming jacks, which are on the front). This allows the connections to be more stable and eliminates or at least reduces them from interfering from using the controls or seeing the display.
The 106 used as a base (or mobile) can cause the radio to fall over due to the antenna connection on the top from pulling the radio down. An external speaker plugged into the headphone jack (to give you louder audio) can make it harder to use the volume and squelch controls. Also the 106's antenna connection is in plastic, while the 197 is on the metal back, which would help it be stronger.
While the 106 can run on batteries and the 197 requires external power, it isn't a good idea to run the 106 for any length of time on external power with batteries in the radio. Although you can do so, it also isn't recommended that you charge your batteries inside the radio. There are many reports of overheating and even serious melting from running a 106 on external power and/or charging batteries inside a 106. Although it should be OK if you use the black battery holder, the power pins can be bent and cause the protection it offers to be gotten around without the user being aware of the problem (http://forums.radioreference.com/gr...00-battery-charging-question.html#post1540250). I'd recommend that you never charge your batteries inside the radio, but use an external charger instead (the radio you save may be your own!).
Antenna connection issues:
* http://forums.radioreference.com/radio-shack-scanners/215881-pro-106-antenna-issue.html
* http://forums.radioreference.com/gre-scanners/222314-psr-500-antenna-connection-issue.html
Battery overheat issues:
* http://forums.radioreference.com/radio-shack-scanners/218491-pro-106-battery-charging.html
* http://forums.radioreference.com/radio-shack-scanners/162387-how-charge-batteries-pro-106-a.html
* http://forums.radioreference.com/radio-shack-scanners/181473-pro-106-charging-case.html
* http://forums.radioreference.com/gre-scanners/211847-psr-500-battery-charging-question.html
