it could be a birdie,
from the manual,
Birdie Frequencies Every scanner has birdie frequencies. Birdies are signals created inside the scannerʼs receiver. These operating frequencies might interfere with transmissions on the same frequencies. If you program one of these frequencies, you hear only noise on that frequency. If the interference is not severe, you might be able to turn SQ clockwise to omit the birdie. To find the birdies in your scanner, begin by disconnecting the antenna and moving it away from the scanner. Make sure that no other nearby radio or TV sets are turned on near the scanner. Use the TUNE function and scan every frequency range from its lowest frequency to the highest. Occasionally, the searching will stop as if it had found a signal, often without any sound. This is a birdie. Make a list of all the birdies in your scanner for future reference.
and it could be picking up the I.F., or a mix product, of another radio, especially if they are close.
the I.F. is a very low power transmission inside every radio.
so if you hear is on one radio, is another radio stopped on something at that time ?
and even the reverse is possible, that the signal is present when scanning and gone when stopped.
in other words, watch the other radios.
