Hard drive volume and drive letter deleted question.
bravo14
Polk County FL
Today I was working on a new hard drive to put win 11 on it for laptop. I bought a offline transfer from hard drive to another. I was desktop and trying to figure out why it wouldn't transfer or the transfer box wouldn't see the new hard drive. Anyways some how the hard drive on desktop I use for backup and downloads and that got wiped out. The volume and drive letter got wiped out and went from bmr to gpt and it got a new volume and drive letter stated the same. I have looked online to find a way to recover the files I lost couldn't find any good ones to try out since they want money up front. Is it too late to recover even it got formatted and volume changed?
bravo14
Polk County FL
it says free, i have never used that one, but have used ccleaner for decades.
i don't see win 11 on there, but you could try.
I downloaded it and did a scan said 0 found. Doing a slow scan see what happens.
  • Like
Reactions: wtp
Kiniutech
Past login as: questnz
Somwhere in the South Pacific
Sound like your partition and master boot record is screw wed up. Delicate operation
There are few FREE Utilities you can download to check this and try recover partition?
New drive have to be Initiated first
Ccleaner is not the tool you use for data recovery it is a CrapCleaner tool for windows and applications, rubbish removal stuff
Recuva is the tool for data recovery, there is very little difference in success between Free pro Pro version
Kiniutech
No is not, if you recover partition you will get your data on that partition.
You got NO backups right ????
GRC is a great Low Lever data recovery software, I used, first some 30 years ago !!!! early days in Data Recovery until more modern tool come on the scene.
bravo14
Polk County FL
No back ups. I was watching the video on grc site and I don't have another computer to run dos or another way hooking the hard drive up to a usb. I might be wrong on that part.
mayidunk
SpinRite is the GRC disk recovery product. If you can mount the drive under any drive letter, SpinRite can access it, and will likely recover it. It ain't free, and there's no demo, but it has performed miracles in the past, and while I cannot guarantee it'll recover your drive, it is likely to be your best shot.
mayidunk
You can create a USB boot drive to boot your computer into FreeDOS, and then run SpinRite off of the same USB boot drive. (it's been a long time since I've used it.) You don't even need to remove the drive, FreeDOS should be able to locate the drive and mount it. If it can mount the drive, then SpinRite can attempt to recover it. It will also run a RAM test to be sure your problem isn't caused by faulty memory, however I believe you can hit ENTER while the RAM is being tested to get out of that test, and proceed with testing the drive, since the first thing SpinRite does now is start testing your memory. If you don't hit enter, it'll keep testing RAM forever, apparently!
dkcorlfla
Orlando
Just wonder if even the partition got screwed up and too late to recover what was all in that drive.
My best guess is your files are still on the HD, it's just the MBR that got messed up. Maybe some searching on ways to repair the MBR on Windows will shed some light.
Kiniutech
If you pay and download SpinRite you can create .ISO file and mount/install on USB with Rufus tool
Then boot from USB so SpinRite can access low lever stuff on your dud drive bypassing Windows OS etc.
Other tools
EseUS partition Recovery
Disk Internals Partition Recovery
Active Partition Recovery
RS Partition Recovery
Hetman Partition Recovery
Restore File Partition Recovery NTFS and FAT
Galore of options, look if you want your data but you are not confident to do it best to take your stuff to qualified Data Recovery people,
bravo14
Polk County FL
All files were deleted when it went to that gpt. The volume was deleted and drive letter stayed as E. I was looking up on how to revert back to the MBR and try scan again.
mayidunk
Unless what you did actually overlaid the data with some other data, or zeros, the data is still there, it's just marked as deleted. SpinRite can recover the data if it was only marked as deleted. As long as you didn't write anything to the drive, the data should still be there. And even if you did, only the part that got over written will be lost. The rest should still be recoverable... hopefully!
mayidunk
Did you actually, intentionally format the drive? Give this web page a read, I think you might be impressed:
One thing about SpinRite, it doesn't care about files, and such. It processes the drive at the physical level. It knows what to look for, and if it sees patterns the look like MBR's, it'll likely restore it as the MBR. If it sees other patterns it recognizes, it might be able to rebuild the whole damned thing!
Kiniutech
If you game go to control panel/windows tools/computer management/storage/disk management
Select the drive click on properties (left side) it will let you convert partition to dynamic disk
Most listed recovery tools will do that for you too.
Bootable SpinRite
GRC | BootAble
Just make sure that Secure Boot is disable in BIOS
mayidunk
Okay. I may have oversold SpinRite a bit. It doesn't recognize MBRs, or other file structures. Instead, it looks for damaged bits written to the disk, and will recover any that it finds. To quote the article whose link I posted above:
"It works at the physical level of your hard disk. It’s specifically designed to work on your hard drive’s magnetic media in two ways.
  • It rewrites data on your hard drive to make sure that the magnetic signals used to encode data are clear and crisp. This makes them easier and faster to read and maximizes the lifespan of the encoded data.
  • It recovers data on your hard drive where those magnetic signals have become weak or corrupted. SpinRite will go to exhaustive lengths to recover data when it encounters a sector that for some reason cannot be successfully read. Once it has done so, it will either rewrite the recovered data to the sector or move the sector to another physical location on the disk."
That same article has a comment where someone has recommended a product called GetDataBack. I'm not familiar with this product, and I have never used it, however it looks promising. Here's the link:
Apparently it's also free to try, though I cannot say that it'll do a complete recovery for free. You'll need to find that out. Also, be aware that SpinRite does it's recovery magic on magnetic spinning disk drives only. If this is an SSD, then GetDataBack may be your only hope.
Kiniutech
Good software but Get Data must recognize Partition and drive letter first if I recall.
if he cant see drive letter it may not work, therefore I would recover partition first and then recover DATA
disclaimer ! Mileage will vary from all tools
mayidunk
Perhaps not. This is quoted from their website:
"GetDataBack Pro can recover your data if the operating system no longer recognized the drive."
Perhaps this is the "SpinRite" of data recovery! (?)
However, all kidding aside, it apparently runs from a bootable USB, and yes, if it cannot mount the drive, then it I can't see how it would work, either.
