hard time programming 996t
balou
ontario
i have the arc 996 v4
i open the software then go to internet and open radioreference click everything i want then send it but it says nothing to scan..what am i doing wrong
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
ARC996 will work just fine - you have to understand how to use Dynamic Memory Allocation scanners. Without much more info here, I suspect you have not sat down and allocated systems, sites and groups, along with quick keys, which are vital to these type of scanners to tell them what to scan.
This article addresses that very familiar problem of 'nothing to scan' (anything in blue is a link)
Nothing to Scan - The RadioReference Wiki
No matter what software you use, these new concepts must be understood. I would sit down with the Easier to Read manual for the 996, and keep our DMA FAQ handy - there's a lot of information there that the manual doesn't have.
You can find links for both here...
Programming Your Uniden Scanner - The RadioReference Wiki
best regards..Mike
balou
ontario
thanks guys..ill try again tomorrow...im off for 14 days so ill play with it...
im used to the pro 96 and 2096 wich is a peice of cake i have 2 of each but i bought a 996t with the remote head for a cleaner install..
