Hard Wiring a Uniden 350a in my vehicle
DMJR318
Moultonborough NH
I have started the process of hardwiring my Uniden 350a Scanner. I have run the power cable under the dash and set the ground. I have located the fuse box in my 2019 Ford Ranger.
Where should I tap in for the best power?
Should I wire directly to the battery?
I am looking for clean power since the 12V plug interferes with my AM/FM Radio.
Thank you
You are on the right track.
Issue is that if you tap into existing vehicle wiring, you run the risk of introducing noise into the scanner.
It's -always- best to run your positive power lead directly to the positive post of the battery with a suitable size fuse at the battery.
Negative should go to a grounding point close to the radio itself. If the scanner is dash mount, it's usually easy to find a screw or existing grounding point.
A lot of people use cigarette lighter sockets or tap existing fuses and suffer from RF interference. Sometimes people get lucky and don't, but it's always a good idea to do it right the first time.
DMJR318
Moultonborough NH
If I run the positive side of the wire to the battery - will I be ok?
Yes, but make sure there is a suitable size fuse within a few inches of the battery terminal. That fuse will protect the circuit in case there is an issue.
Pretty standard 2 way radio install type work.
