Harford must be the only county I've ever heard in the last 15 years still dispatching with 10-codes. Anyone know where I can find the meanings?
Google is helpful with most things, however this whole website is for this type of question.Google is pretty helpful with that!
ThanksHarford County only uses two 10 codes for fire department. The code 10-50 refers to a motor vehicle collision and the suffix PI personal injury or PD property damage determines the type call. The second code is 10-99 which means crew requested or unattended unit or a company has been alerted for more calls then they have staffed medical units. That code is becoming less common because of many staffed ambulances. The only other MD county I know that uses 10-50 is Talbot county. Other then that most departments have switched to plan English.
Talbot typically uses "mvc" when dispatching a rescue box assignment. Their law dispatch still uses a variety of ten codes though.Harford County only uses two 10 codes for fire department. The code 10-50 refers to a motor vehicle collision and the suffix PI personal injury or PD property damage determines the type call. The second code is 10-99 which means crew requested or unattended unit or a company has been alerted for more calls then they have staffed medical units. That code is becoming less common because of many staffed ambulances. The only other MD county I know that uses 10-50 is Talbot county. Other then that most departments have switched to plan English.
