Graysman said:
I have a Uniden BP-250 scanner. I don't think its the scanner because I can pickup channel A. Channel B (the main channel) went silent about 3 weeks ago.
Ok, yes that's digital... I wonder if something else changed with either the scanner or the post radios. You might want to make sure your card is seated correctly and working.
And hopefully somebody closer will know something.
I looked at the database, it's only 25 watts output. Maybe changed antennas, is that the closest location to you?
What does this frequency get you? 460.43750 And I'm with Unitcharlie, try programming all the other frequencies and see what happens. With KY being broke... if a problem it maybe a long time before it is fixed if broken, not to mention far away from Frankfort which is where I would guess the radio techs work out of.
I know at my location, I have trouble hearing KSP, even when i am traveling in Louisville.
