HARNETT COUNTY: Rebanding Update
StitchMagician
Dunn
The Harnett County EDACS system rebanding will enter Phase II in December. At that time, all portable radios which must be replaced will be exchanged with current programming installed. Work on all mobile radios will then proceed.
Once all necessary portable and mobile units have been replaced so that the system is ready for the new programming, Phase III will commence and final programming will be implemented.
I have no concrete dates for Phase III.
StitchMagician
Dunn
Next phase underway...
All the unrebandable handhelds have been replaced with Jaguar 7100's or 5100's.
Beginning Monday, March 2, 2009, all unrebandable mobiles and desktops are to be replaced. Not sure how long this procedure will take, but have been told it could take as long as 3 hours per mobile unit, so we may be at this point for a while.
Once all the mobiles and desktops have been replaced, it will be time for the next phase which should be the actual rebanding.
I'm hoping to be able to converse with a radio tech in the next week or two so that I can have some definitive information for you.
Stay tuned.
kirka127
Boy this whole rebanding thing sure is taking a long time LOL Thanks for the update and look forward to any updated info you post.
Kirk
StitchMagician
Dunn
UPDATE: The non-rebandable mobile units continue to be removed/replaced. There are nearly 350 of these units and it is taking approximately 3 hours/each to effect the change.
All of the non-rebandable portables have been replaced and are in service.
The telecommunications personnel told me yesterday that it will be mid-May before the project is complete.
I have been promised site freqs and TGIDs as soon as they have been finalized.
I just messaged ROBBYBOY and assured him that I will submit ALL this information to the database just as soon as I get my hands on it.
I've reviewed the information in the database and it is reasonably accurate at the moment. There are a few errors and omissions, but nothing that would disrupt your monitoring.
As soon as I know, you will.
StitchMagician
Dunn
UPDATE: I spoke with one of the rebanding technicians this afternoon. New radio installations and reprogramming is nearly complete.
The next step is reprogram the tower sites. When this occurs (approximately mid-May) it will appear to those scanning that Harnett County has gone off-the-air. It will be as simple to fix as adding the new freqs. I'm trying to get my hands on that information as we speak.
Once the towers are complete, if all is still working well, then the new talk group id's will be programmed into ALL the equipment and all the prerebanding information will be deleted.
We're almost there. I'll let you know as I learn more.
basstuba
Raeford
update rebanding
851.1375 lcn 9 c.c. unitrunker has lcn 10,11,13 for channel lay out.
basstuba
Raeford
lcn spout springs?
with unitrunker the new lcn 9-851.1375,10-851.575.11-852.600,12-852.900
13-853.9375 .
kirka127
that explanes alot
I was wondering why I was not able to track the new frequencies. I had the new ones for spout springs tower as 1 thru 5 like the old layout. Gotta get busy reprograming.
Thanks a million Kirk
Chris-KH2PM
Northern Harnett Co. NC
I'm working with a control channel of 851.4125..LCN 09 on UniTrunker Retro. Trying to figure out the other frequencies and LCN.
From my location I'm getting the Control channel from 30-55% with an attic mounted RS Discone.
Chris-KH2PM
So far it's up and working, using a PRO96 to scan from 850-855. I found five frequencies that match up with activity on UniTrunker.
Using Control Channel 851.4125 (the strongest one, I can also hear 852.5625 but it's unusable), I have come up with
09 851.0875
10 851.4125
11 851.9000
12 851.9500
13 852.1125
Still verifying the frequencies, as some are so weak they may be for another site. Yet activity on UT matches the activity on the frequency as I monitor it.
Curious as to the odd LCN, starting at 09. I input the same freqs and LCN into my 396 and it's working great from Holly Springs.
Hearing a lot of "Test 123" comms going on right now...
kirka127
09 851.0875
10 851.4125
11 851.9000
12 851.9500
13 852.1125
That would be the cokesbury tower Old site 004
Also picking up CC on 852.5625
this would be the western tower.
should be
9-852.3375
10-852.5625
11-852.8375
12-853.3375
13-853.6000
Hope this helps Kirk
kirka127
I just programed the new frequencies in starting with LCN 09 thru LCN13 and that is the correct order for the western tower.
kirka127
could anyone verify LCN for Lillington tower
9-851.0625
10-851.3375
11-851.5625
12-851.8375
13-852.0625
and Angier
9-851.05
10-851.6625
11-852.475
12-852.925
13-853.275
I can not pick up those towers from my house.
Thanks Kirk
KE4ZNR
Radio Geek
Quick request-
When yall get this all figured out (and it looks like you may already have) please submit the verified info so that one of us database admins can update/correct it.
Thanks!
Marshall KE4ZNR
kirka127
Info submited
Quick request-
Thanks!
Marshall KE4ZNR
Marshall,
I submited the reband info to be corrected in the database.
Kirk
KE4ZNR
Radio Geek
Wirelessly posted (KE4ZNR's HTC PPC 6800: Mozilla/4.0 (compatible; MSIE 6.0; Windows CE; IEMobile 7.11) Alltel HTC PPC6800)
kirka127 said:
Quick request-
Thanks!
Marshall KE4ZNR
Marshall,
Kirk
Thank you Kirk.
Myself or one of the other admin crew will work it asap.
Thanks again for everyones hard work in getting this info together.
Happy Monitoring!
Marshall KE4ZNR
