Harris dsdx01-vs
Muxlow
Super Secret
Middlesex County
I picked up a new HARRIS DSDX01-VS desktop station for an Orion
It didnt come with a power cable to connect to the power supply, But reading the manual o figured out i had to make a little 2 prong connector for the desktop station to power up and plus the orion power cable directly into the power supply molex connector
Question here now is i have the REMOTE and INTERCOM switches and they do nothing when i toggle them. Also the microphone jack on the console itself does nothing but when i connect the mic to the radio itself it works. What is missing for these options to be functional? Is there a dip switch or something that needs to be changed inside the console itself? I see a few in there but no idea what they do
DisasterGuy
Maryland Shore
Based on what you have posted it sounds like the desktop enclosure may have been chopped up (ie: it is missing the power cord). There are multiple boards and board configurations for these enclosures that allow various remote configurations including the use of the DDC-100, DC remote and/or tone remote. What exactly are you trying to do?
Muxlow
Super Secret
Middlesex County
Yeah was for sure missing the power cable so i took a old floppy drive cable and cut that for the connector and the station powers up now
The remote function i wont ever need, What does the intercom do? and any clue why the front mic jack on the station is non functional? The mic thing is the only thing id really like to do something with
DisasterGuy
Maryland Shore
Intercom is used with the DDC-100 remotes to allow intercom functionality between remotes without going over the air. More info here: https://www.ycdes.org/docs/TE_M7100Desktop-DDC100-UsersGuide.pps
The use of the mic jack on the front of the control enclosure depends on how raped the main board was, jumper settings on the board if it is even there, etc. In general we just use the jack on the front of the radio itself unless there is a need to interface through a remote board and/or integrate a logging recorder.
Forts
Ontario, Canada
I saw a few of these in use a few years back (Muxlow will know where) and they all had the mic plugged into the radio from what I recall, not the enclosure.
claman5
New Port Richey, Fl.
Harris dsdx01-vs radio base station HELP
Hello to the group,
I have a HARRIS DSDX01-VS RADIO BASE STATION that I have got a M7100 installed in it.
Everything is working fine with it as it is a blank frount end.
Is there a manual or LBI on this item that I can find part numbers for various front panel items like program plug, switch for NORMAL/PROGRAM, VLOUME KNOB and others?
Thanks for your help
Bill
CSHIFTLT
Henry
radio also has to be programmed for the aux mic/ptt, if that is what you want to use. and correct jumper on board of desktop box. intercom switch shoudl be in middle position if no ddc connected.
claman5
Just looking for HELP or manual or LBI on this item that I can find part numbers for various front panel items like program plug, switch for NORMAL/PROGRAM, VLOUME KNOB and others?
Bill
Muxlow
Super Secret
Middlesex County
Where could i find one of these DDC's used of course. Iv got the DDC100 board inside the unit
ElroyJetson
This is a combined answer, answering questions posed by more than one person.
The intercom and remote switches only work if you have a compatible remote connected to the unit via the remote jack on the back.
What's a compatible remote? It totally depends on the optional remote interface board type that is in the unit. On an EDACS station, it's a Select 5 board which is a tone remote unit that is limited to five channel/talkgroup operation. And it's quirky, as the tones needed to access the five channels/talkgroups are NOT in the usual EIA tone order for an industry standard tone remote.
Channel 1 uses the regular channel 1 tone.
Channel 2 also uses the regular channel 2 tone.
But 3, 4, and 5 use tones assigned OTHER tones. I think it's EIA tones
for channels 7, 8, and 11, but It's been a while and I'm probably wrong.
If it has a select 5 board, it works with a tone remote. If that tone remote has intercom functionality, you can use it to speak via the intercom function to someone standing by the desktop station.
If the unit has a DC remote board, you need a matching DC remote.
All you need is any DC remote if you want to make use of the remote and intercom features.
I've got a PILE of CPI DC remotes just sitting in my warehouse, waiting for me to get around to selling them for probably 30 bucks each on fleabay. I'll sell you one for that price, just PM me.
There's at least one Orion desktop on fleabay right now for something like 90 bucks. I suggest buying that one for parts, or swapping your radio into it.
