Harris HDR100
carlost11
Hello to all,
I have recently bought a Harris Momentum repeater and I'm trying to convert the firmware from a Harris to a Hytera since Hytera is more HAM friendly. After several weeks of research I have hit a wall. If someone can help me or guide me in the right direction I would appreciate it. There is a slew of information on the Hytera but very limited on the Harris. Thank You in advance..
ke3jp
Greenville Pa 16125
No I have not found out anything kind of something anyone wants to help out with so the repeater and 5 handhelds are in the box in the closet awaiting to come out
ctrmass
oean county, nj
I believe 7 is the latest.
There are some who converted the Momentum mobiles to Hytera.
One is on the RR forums, name is "Forts" and I believe he's in Canada.
From what I remember, the older firmware was easier to do, newer ....not so much.
ke3jp
Greenville Pa 16125
still looking to convert the Momentum handhelds and repeater to Hytera
I hear people talking about it but no information yet on how to do it
thanks for any good info how to do this Mike ke3jp good on qrz.com
ctrmass
oean county, nj
Go find Forts and ask him.
From what I remember, the older firmware radios are easier to do, just wipe it clean & reload as a Hytera. Newer fw models are tricky.
Forts
Ontario, Canada
Hey guys.... yes that is correct. The radios I did had (I believe) v4 firmware in them. I think the cutoff for doing it (at least the way I did it) was v5 something. Basically it's a matter of tricking the Hytera firmware updater to accept the Harris model # as valid. The other option of course is sticking with Harris firmware which ended at 7.something.... but more most folks that's usually sufficient.
ke3jp
Greenville Pa 16125
but how do you trick the software to do it ?
Forts
Ontario, Canada
I'd have to find my notes, it was many years ago that I did this.... But basically you have to edit a config file in the Hytera updater. Basically it holds a master list of acceptable model #'s for that upgrade and you have to insert the Harris model # into that. Do you know what firmware version is in your radios?
ke3jp
Greenville Pa 16125
I think it 4.0
