Harris m7300 [deck and head connection]
LowderK
LEO / Paramedic
Western Oklahoma
OK here is my question i have a m7300 7/800 radio with system head between the Deck and head i have a CAN cable……. i have a M7300 VHF deck and system head but can’t find a can cable …. is it possible or do they make a cable like the old m7100/orion cable you can use instead of a can cable.? from the DB connection to DB connection…?
ElroyJetson
There's the CAN cable. I don't think there are provisions for the M7300 to operate with an M7100 type control head, if you were thinking of trying that. There is a DB25 on a CH721 head so maybe a DB-to-DB connection is possible but for the effort involved, even at 90 dollars it'd be cheaper in time and labor expended to get the CAN cable.
merlin
DN32su
The CAN cable is the same for all the M7300 to 721 head.
Same cable with the XG-75M/Xg100M also.
No, an M7100 CH will not work with these radios.
The DB 25 connector on the CH-721 is exclusively for the external accessory cable.
LowderK
LEO / Paramedic
Western Oklahoma
OK here is a CH-721 control head question….. is the button caps still available for the system head to change what the keypad buttons say so they match what they are assigned like yelp, or siren or ext speaker etc….? if so does anyone have a list of what’s available?
ElroyJetson
Keys in kit KT-013492-003 include:
 SYS,GRP,OPT,MENU,STS,MSG,CLR,PHN,DIS,IND,ALM,SG1,SG2,SG3,SG4,SG5,YLP,RST,WAIL,SL1,SL2,SL3,SL4,SL5,SL6,SL7,SL8,SPK,STO,ST9,PVT,KEY,GE* ,PA,MODE,HOME,CHN,#,AUX1,AUX2,ST1,ST2,ST3,ST4,ST5,ST6,ST7,ST8,1,2,3,4,5,6,7,8,9,0,*
 Quantity = 5 blank black plastic small system keycaps
 Quantity = 3 CH-721 Emergency button with the following text: E. “E” will be shown in white plastic with red ink background
BMDaug
I am licensed…
Central Colorado, USA
New London doesn’t like that it part #… that’s always a bummer. I love it when I put in the part and it says “42 available”. Sometimes it’s easy, sometimes not. Good luck!
-B
