I have a UHF P5450 comprising:
Firmware v07.29
PERS 54.00
Personality P7100APC
Flash P53U0729
Build 21 May 2009
DSP 07.28
H/W Rev B
Features 01, 04, 07, 08, 09, 10, 12, 23, 33, 39
I am looking to program the P5450 on P25 conventional (not trunking) and analog.
I have a serial programming cable for the P5450....not a USB cable.
My "serial port" programming laptop only runs XP. My Win 7 programming laptop is only USB...and I prefer not to use a serial to USB adapter as they can be unreliable!!
I have checked "official" documentation which only mentions the RPM software as being compatible with Win7/8/10.
But I read that somebody was using RPM12 on Windows XP and it worked OK.
So will I be able to install and run RPM R14C05 on a Windows XP laptop?
Is there any reason NOT to use RPM R14 vs an earlier version of RPM ie any wideband restrictions?
Are there any issues with matching early firmware (like on my P5450) with later RPM software...the radio has probably not been programmed for 10 years...or does the RPM software automatically update the firmware to match the RPM software version when you run the software?
Firmware v07.29
PERS 54.00
Flash P53U0729
Build 21 May 2009
DSP 07.28
H/W Rev B
