Harris Momentum HD-MV1B
DatedGore
Indiana
Hello, I was looking at a Harris VHF Mobile, its a Momentum hd-mv1b. I couldn't really find any info on them at all, I've heard some of the Momentum series are front panel programmable, does this vary from radio to radio or will this radio be FPP as well? Or will it require RPM and a programming cable?
Thanks.
TDR-94
RPM is only for L3H Public Safety radios and certain military handheld applications.
TDR-94
I believe the Momentum radios require the HARRI$ Momentum programming software. Others on here, that are more familiar than me with the HARRI$ rebranded HYTERA radios, could better answer your question about whethet or not they are actually capable of FPP.
Forts
Ontario, Canada
It is just a rebranded Hytera MD-780. I have one at home (780 that is) but I've never tried FPP on it. I assume it's the same as their portables. You can change some parameters of already programmed channels but generally not create something fresh from scratch. And they do require the momentum software for programming.
radioopperator
Uses HYTERA programming cable BUT HARRIS MOMENTUM ver 6 or 7 CPS.
