Harris P25 phase 1 system on a Motorola radio?
W4KRR
Coconut Creek
Is it possible to program a Harris P25 phase 1 trunked system on a Motorola radio?
I have no trouble with Motorola 3600 baud analog type II, Motorola P25 phase 1 systems on an XTS2500. but on a Harris P25 phase 1 system, the radio won't unmute. If I program the voice channels in conventional mode with the proper NAC, I can hear digital audio. Programmed as trunking, nada. Is it a setting somewhere?
KevinC
Junior Radio Guru
Home
If I remember correctly, the issue will be "Intra-WACN Roaming" will need to be checked...which will take a WACN ASK.
You may have other issues as well, but I'm pretty sure this will need to be checked.
parma,ohio
mine works fine with out checking the Intra-WACN Roaming box if hes trying to monitor that system with out using Non-Affiliation the radio will NOT unmute to monitor with out a LEGAL radio ID.
KevinC
Junior Radio Guru
Home
On a Harris system?
KevinC
Junior Radio Guru
Home
And to note, not all Harris systems need this to be checked, only ones that use a oddball NAC for the VC.
Forts
Mentor
Ontario, Canada
I have several local Harris systems, all work just fine on Moto gear. Never had to mess with the Intra-WACN and the RID is not relevant (because the radio won't be affiliating with the system... RIGHT?). The only issue I have around here is that the Harris systems typically use a non-standard base frequency which needs to be accounted for in the Astro25 Channel ID tab.
KevinC
Junior Radio Guru
Home
APX or XTS/L?
Forts
Mentor
Ontario, Canada
Sorry, I should have clarified. XTS/XTL. And by using a non-standard base frequency that eliminates the possibility of using older Astro gear like the Spectra and XTS3K (as the base frequency cannot be edited in Astro CPS... Only Astro 25).
W4KRR
Coconut Creek
Make sure the proprietary options features are unchecked.
Could you be more specific?
Also, I found some info on another radio website that says this:
"The radio is attempting to validate the NAC on the P25 voice channel the control channel points to. When the system ID doesn't match up with the NAC on the channel, the radio thinks the traffic does not belong to the system and will not unmute. The work-around for this problem is Intra-WACN Roaming, combined with the correct WACN ID. This effectively disables the check, and allows a Motorola Astro 25 radio to monitor a Harris system."
Project25_MASTR
Millennial Graying OBT Guy
Texas
Under Trunking System>Astro 25...Motorola Prop Features. It is selected by default when you create a new system. I've always thrown the WACNs in just out of habit. Don't think I've actually played with a system requiring Intra-WACN yet.
KevinC
Junior Radio Guru
Home
That is what I was referring to. If the system uses NAC's for the VC's that aren't what the Motorola expects them to be it won't unmute.
Not all Harris systems are like this, but I believe most of the newer ones are.
