Thank you for the nice response it’s all the correct band and everything as well thanks you for your time!
OK.
So, yeah, finding people that will actually do it may be difficult. Most radio techs don't work cheap, and programming a radio from scratch on a trunked system takes a lot of time. Plus, unless they are local, some of it is kind of trial and error since they can't be there to actually check the stuff.
The agency radio shop likely will not help you unless you had the support of the agency, even for RX only.
So, finding a person with the knowledge, RPM software, cable, and willingness may be difficult. Then you have to pay them, and they get to pick the price.
Which is another reason to get a scanner. Buying trunking capable radios, like the XTS and Harris can get expensive unless you have the skills/software/cable to do it yourself.
