Harris System Issue
WX4JCW
Stow, Ohio
Hey Everyone,
got a little bit of an issue, I am trying to program in the new Reno-Washoe County system in my G4, I triple and quadruple checked that ALL the channels were in, SYSID and WACN were correct and talk groups were programmed in properly.
however upon reboot, the system shows out of range and no matter what it won't lock on, I've had this happen when I had the SYSID and WACN programmed wrong in other areas, I also programmed a known 800mhz conventional frequency in the thought there might be something wrong with my radio but it works
any Ideas (See Screenshots) Here is the database entry - Washoe County Simulcast Trunking System, Reno, Nevada - Scanner Frequencies
Thanks in advance
APX8000
Sarcastic Member
AES-256 secured
I’ll bet the database has an incorrect RFSS. Change the RFSS and Site to FF’s to double check. Same for the WACN. It will display the correct ones once is locks on to the control channel.
APX8000
Sarcastic Member
AES-256 secured
Oh wait you said HARRIS. Program ALL the frequencies. Harris systems can use any channel as a control channel. Database is only showing 4 channels I’m sure there are a lot more judging by the amount of talkgroups. Check the FCC license.
WX4JCW
Stow, Ohio
did that as well also concurrently monitoring on my SDS200 so it should work
