Harris Unity / XG-100 wideband option
tleck330
KD2VDN
Webster, New York
I know this is an old thread but looking into a 100m to go along with my 100p. Are there still ways of getting features added to the 100m? Thank you in advance…
merlin
DN32su
Interesting thread all the way around.
Can the XG100M be "unbricked" without TAC after a botched firmware upgrade? I've got one sitting on a shelf that was given to me non-op because a local shop tried to upgrade the firmware and "messed it up"...so I'm assuming they went out of order or something.
IF, and only IF the radio will still connect with RPM/Maintenance.
If not, it takes some minor surgery and a load of special procedures to blow a new bootapp into the radio.
You get that "lost/no MRU" error, it doesn't look good.
motorcoachdoug
Silver Spring, MD
I have the name of a Harris Dealer that I have been dealing with for the past 2 years now here in the DC metro area. I would like the wideband removed from my XG100M also but unless you can give Harris a legit reason why and being a ham will not work, then you are totally SOL. However I wonder if they would take that You are in the USCG Aux and use your own boat for patrol ??? hmm I think they would want prof you are in the USCG Aux as well. If anyone wants the contact info for the dealer give me a PM
rescue161
KE4FHH
Hubert, NC
The radio already does marine wideband whether the radio has wideband disabled or not. It also does 2m ham, but does not do 70cm ham, nor does it do GMRS. Everything else would be narrowband.
merlin
DN32su
I thought it strange that a few 2 meter repeater frequencies simply default to wideband and greyed out in RPM.
I am going to try some NOAA sat freqs and test the raw audio from the accessory port.
Low band frequencies also default to wideband.
I don't have UHF so can't vouch for that.
I am a lineman for the county.
I don't know about the XG-100, but the XL-200's will do wide on the VHF marine channels, as well as 2 meter frequencies, just fine.
To get wide band activated on my XL-200's, I had to send in a letter stating why I needed wide band, as well as copies of the licenses that showed legal use of wide band to get it activated.
TDR-94
I forgot NOAA in the list of authorized wideband freqs.
I don't know if it's now supported, but initially the XG-100P would not allow you to enter the WX frequencies as WB without the WB feature enabled,. It would give you the INVALID SYS error if you selected a system with those frequencies set as WB.
n9ihx
Chicago Area
Anybody know what the cost of getting the wideband disable removed from a xg100m would be if its even possible through a dealer.
Don't have a dealer close to me that I know of. I am in Moto country here in northeast Illinois.
I just did it for my XL-200's at work.
Since I'd recently purchased them from a dealer, I was able to get it done for free. They did require me to write an e-mail justifying the need, and including copies of FCC licenses that were still wideband.
wa8pyr
Technischer Guru
Staff member
Lead Database Admin
Ohio
But not on the UHF ham frequencies, unfortunately.
wa8pyr
Technischer Guru
Staff member
Lead Database Admin
Ohio
And good luck trying to get Harris to simply update the frequency limits vs narrow band limits in the firmware so that UHF ham and GMRS are wideband right out of the box. I tried, and got the cold shoulder. Apparently simple logic doesn't apply in this scenario.
I've often wondered if that was due to ham being the secondary allocation on those frequencies. Maybe not, but it would be a good excuse.
Right, but to be fair, the radio does not have Part 95 approval. Again, another good excuse.
redbeard
OH, PA, WV Regional Admin
BEE00.348-3.1
IIRC the couple wide MURS channels also will not program as wideband. Same reason as GMRS I'm sure. There are some broadcast allocations still authorized for wide and not sure if those will work or not. Also haven't tested T-band freqs which are still allowed wide.
vittles04
Premium Member
Michigan
Contacted a few dealers and obviously know the game. But if the successful person on here see's this please please PM me. I have a 100P and 100M.
