Harris XG 100 M Unity Multiple P25 Trunked system scan?
Coxie
Idaho
The Brochures I've seen all state multiple P25 system scan.
I've been able to get conventional Analog and conventional P25 to be scanned while on a P25 Trunked channel. No luck getting to scan between different P25 trunked systems.
Is this even possible? Is this a feature that must be purchased?
Coxie
WNZT398
Capon Bridge WV
Coxie
How are you looking to scan? Two P25 systems in range and the mobile samples both and receives calls on whatever has a call? OR The mobile radio no longer receives a control channel signal from the selected P25 system and then scans to another P25 system looking for control channel signal?
Coxie
Idaho
WNZT398,
The first one you stated :
" Two P25 systems in range and the mobile samples both and receives calls on whatever has a call..."
I can get it to scan to other P25 trunked systems when a control channel is lost.
I can get it to scan Priority to P25/Analog Conventional when on a trunked Talkgroup.
I cannot get it to scan TWO P25 trunked systems simultaneously and receive calls on both.
Thank you for your response.
Coxie
WNZT398
Capon Bridge WV
WNZT398,
Coxie
Don't think it is designed to scan this way but I will inquire at Harris support.
