Harris XG-100p Intermod/Interference from Display!
W4UO
Kodak, TN
I have a strange noise that is only affecting 1 conventional analog frequency in VHF range. The odd part about it, it is common to any location, so Im assuming internal radio noise. Placing 3 fingers over the display will cause it disappear. Is not present in TX. Ive only expreienced this in the past when there have been loose/dirty connections.
Im very green to the harris so I thought I would reach out and see if any more experienced can give me some ideas.
W4UO
Kodak, TN
Ok for anyone that runs into the same issue. What fixed this internal noise for me , was to disable the radio to the point fist board you encounter is removed and using a platsic pry tool I worked around the board below. This loosened up what sounds like contacts below that were spung for tension. Reassembled radio and tightened down screws. Screws were loose to begin with. This WORKED! No more internal noise on vhf. See how long this lastest as Im betting its just corossion causing bad connections.
Ive ordered new front, knob kit , battery. Will clean everything during that install process.
W4UO
Kodak, TN
Disassemble not "disable".
