Harris Xg 100P NAS help for the new MERA System
UTLForlife
Okay so can someone tell me what I am doing wrong? I am trying to program the new Marin Emergency Radio Authority (MERA) system. I am not getting any traffic from the site ( I am trying to get the East Simulcast Cell to work, I feel like it has something to do with my trunked frequency sets. I believe I am supposed to either have a +45mhz offset or -45mhz offset. Unfortunately when have the positive 45mhz offset I keep getting a "Invalid Frequency value- Improper channel spacing" error. Then when I do the negative 45mhz offset I get an "Invalid Tx Frequency entered" which makes sense.. so at the moment have a positive 30mhz offset because the IDEN has a 700mhz freq in it and i figured i would try that.. that's probably wrong and I am new to programming trunked sites. let me know if any of you have thoughts, thank you for your time.Screenshot 2024-11-03 120724.pngScreenshot 2024-11-03 120745.pngScreenshot 2024-11-03 120803.pngScreenshot 2024-11-03 120823.pngScreenshot 2024-11-03 122913.png
northstarfire0693
North Carolina
Try changing to Fixed proscan instead of Enhanced CC. Harris radios dont like that too much when you have other TRS in the area. Double check your offsets. Add site 2. Its a simulcast system, the radio will switch between them depending on the strongest RX.
UTLForlife
Awesome thanks for the reply. I have heard about the Fixed proscan.. ill give that a shot. Could you spell out what my offsets need to be? I think my dyslexia is getting the better of me. I appreciate your time!
UTLForlife
Okay, so I turned on Fixed proscan and double checked my offsets, they're all +30mhz on the TX side. I also added all the non control channels to the trunked frequency set list and I have the CC limits set to the first 5 because they are the control channels. If you have any other thoughts lmk!
northstarfire0693
North Carolina
Check your DM.
