Harris XG-100P
gdsteele
I don't have any problems either. I have a couple of trunked systems in mine.
TDR-94
Is a system key required to monitor a trunk system phase 1 or 2?
Using firmware version 6 and software version 14.
Yes,an AAC (WACN Key) will be required if you're using a legit version of RPM14 with a license key from Harris.
Radioman96p71
The firmware used with RPM14 is not compatible with RPM10. You would need to get the radio downgraded to XGP R02A26 to use RPM10.
ppostewart
Venice, Florida
after updating the firmware xgpro 2a26 to xlpro6 G03 and using a working mission plan but now it lost the p25 phase1 and phase 2 channels. How ever if I leave it on for a hour suddenly it starts to work again. Any one have a clue what it happens as I wanted to have the newer firmware for the DTMF feature.
