Harris XG75 KFD Tool
AESFTW
Has anyone had any luck keyloading an XG75 or similar with the KFD tool? Also, does anyone have a schematic or pinout for a hirose keyloading adaptor to UDC? I figure the standard audio hirose adapter for the XG series will not work. If anyone knows or has experience with this, let me know. Thanks!
prcguy
Not sure what cable the XG75 uses but I'm able to keyload XG-100s just fine with KFD.
snoopyII
On the other side of the tracks
I've Keyloaded XG75M's with no problems as well with KFD. The part # for the mobiles is 14200-0143-10. The part # for the portable is 14002-0143-01. I haven't personally seen the latter, but I suspect it has the same inline converter box as the mobile just with the UDC connector, not the 44 pin. Be prepared to drop about $250 on it. The cable itself must be modified to plug into the KFD. I had looked into this project once as well, and I do believe you are correct as a standard audio adapter won't work as-is. I have the pinout somewhere, just cant seem to find it.
Jace1986
I have zero issues keyloading my XG-100P and M with my KFDtool. I reached out to the maker of the KFD tool on the github and he custom made me the two cables for a fee. I have also keyloaded my XTS2500’s with zero issues for what it’s worth..
AESFTW
Yes I have no problem whatsoever with Motorola products. No documents whatsoever on the XG75.
