Ha! That must be why I’ve always had the edit button! I’ve never loaded a mission plan without pins set for all functions… thanks!!!You'll also need to have a pin set in order for it to show the "edit" function. Without the pin, it'll not let you edit anything.
XL-Radio options (bottom of the options list) in RPM… there is a Channel Edit Password. Set that… I also set a Maintenance Password (to something different).How do I set a pin?
-B
FPP is standard and is not an optional feature.My Harris catalog does not list the FPP option. What would that run to get it in my 185 and what's the part number for it?
Unfortunately… especially when you have the NIFOG plan loaded… if you have that, all you really need is the ‘change CG’ menu option just to be safe.That's pretty neat. Too bad that feature is of very limited utility on a 7/800 radio.
It’s under power up options. You can set a pin and optionally set the radio to zeroize all keys and plans after a particular number of failed pin entry attempts.I haven't found it so maybe it doesn't exist but I'd like for there to be an option where I have to log in on the radio on power-up or it remains locked and unusable. Yes I know that exists for P25 but I mean for other modes. A power-on password.
I think that'd be a good option for all high tier radios. With an "erase personality or delete firmware on X login failures" option as well, for system and user security.
That's how my 100p is setup. It's a nice bit of peace of mind.I haven't found it so maybe it doesn't exist but I'd like for there to be an option where I have to log in on the radio on power-up or it remains locked and unusable. Yes I know that exists for P25 but I mean for other modes. A power-on password.
