scanphreak
hmm
I am using the Larsen tri-band scanner antenna, NMO mount on a groundplane ate about 12 feet. Signal strength seems good, the analog stuff from that system is fine, just the ProVoice seems to be giving me trouble.Since you're over in BSL, have you tried taking the SDS100 in the car for a trip east into gulfport at least? See if the audio gets better. I saw your signal strength and it looked okay to me. But I see what you're saying. I don't have those issues over in Jackson County. But I'm probably 8 air miles from one of the towers. You might be on the fringe of it. How about trying an outside antenna, or maybe a directional antenna like a small 5 element 800 mhz yagi?
where's your proof of this statement? show me an official article or document saying that harrison county was giving up their edacs system for MSWIN? Why would they? They spent millions on it, the support from harris is there. they keep upgrading their radios. No one has made any effort to move to P25 in harrison county.They are going be be switching over to MSWIN so I'm told...probably sooner rather than later.
Be safe
Ok well yeah. I saw your signal strength looked adequate, and since you're using an antenna outside 12 feet up should be good enough. There must be something off on the setting. Have you gone into the uniden tavern and asked if anyone else with the sds100 is having that issue with provoice? What about MSWIN how does that sound? Are you monitoring hancock/bsl/waveland law enforcement?I am using the Larsen tri-band scanner antenna, NMO mount on a ground plane ate about 12 feet. Signal strength seems good, the analog stuff from that system is fine, just the ProVoice seems to be giving me trouble.
What are the MWCC minutes?To find data on the upgrade, read the MWCC minutes. That is the definitive radio info source for anything upgrading or changing or new in MS., You have to go through the MWCC to get r done. EDACS has been disconned for a few years now, and support is beginning to phase out rather quickly. They will either be upgrading to an Harris P25 ip, or joining the MSWIN, and sooner than later. Just pray to God they are smarter than City of Jackson was in its upgrade.
Very good, thanks.
