Has a server gone down?
feedus
Perkasie PA
mine is down too. Audio 1 server problems again. Wish there was a way to switch servers. I have recieved about 25 emails about my feed being down from listeners since just before mid-night EST
redhat
Ventura, CA.
Same computer feeds two scanners to audio1 and audio6. Audio1 will not connect. Audio6 is working.
scanmorgan
Lake of the Ozarks
I did a remote ping to audio1.radioreference.com from my webserver just to make sure it wasn't my connection. Same thing, ping timeout. audio6 pinged back good though. I think I've always been on audio1... I've always ran tags with my feed as well if that makes any difference.
feedus
Perkasie PA
I just made it so that the listeners can connect directly to the ScannerCast so they can listen. Hopefully this will work til they can fix the server problem
feedus
Perkasie PA
how do you do that?
Open a port (port forwarding) on you computer. Then on scannercast config tab click on it and you will see SERVER. Enter a stream name, enter description and the port that you opened, place that in the server port, make the Max connections 0 and click on start broadcast. follow the instructions on scannercast's website.
K9GTJ
Kokomo, IN
After trying to troubleshoot for 20 minutes, I find this thread. At least I know I am not the only problem...
