Has anybody encountered difficulties deleting rows from the Proscan Recorder?
jjn555
Milwaukee, WI
I have about 5 days of recordings from a very active local system and I wanted to save those and 'clear' out Proscan to start with essentially a clean slate. I could delete the UIDs in the UID table just fine, but then when I tried to delete the recording from the recording tab, I couldn't even delete one row, much less all 2700 of the rows. I'm running the latest version of Proscan.
ProScan
Software Provider
Ontario, Calif.
Are the Save check boxes checked.?
Firebuff66
CT
Did you turn the record off first?
jjn555
Milwaukee, WI
No. Just uncheck the Save boxes of the rows you want to delete.
BINGO!!! That worked. TBH, I hadn't noticed the Save boxes before. I had to 'UNSAVE all boxes" and then Select All Rows, and then Delete Selected Rows. I'm definitely not complaining, but that's one sequence I hadn't obviously tried before. Thank you, sir.
