Has anyone been able to get text tags from a PRO-18?
scosgt
I have tried to get metadata (text tags) from my PRO-18 to Radio Feed by Proscan on two different computers.
So far, no joy.
Anyone had any luck? The program states that it does support text tags on the 18, I just can not seem to get there from here.
ProScan
Software Provider
Ontario, Calif.
RadioFeed supports Pro-18 text tags.
Is the RadioFeed scanner type set to Pro-18?
Do you have a cable hooked up from the computer to the scanner?
Is the correct RadioFeed port selected?
Do you see the RadioFeed scanner data light flash?
Set the Custom Format to %C - %FT.
The text tags should show at the bottom of RadioFeed if all is working?
Turn off the scanner simple view to display the TGID.
scosgt
Yes, correct radio
Yes correct cable and it does show up as a serial port
NO, the data light does not flash. No data being read, no display of data.
Is there a setting that needs to be made in the radio?
