Mogman
37 years as a communications specialist for a major pipeline company, mostly dealing with Motorola radios, I think I will be OK, I cut my teeth on Twin Vs and Motran/Motrac radios and DOS, I have however not had much experience with Arduino so the lingo is not familiar to me.If you buy everything you need from one of the above vendors, things will just work, or you’ll get help to make it work as sold. Accessories will also typically mix-and-match across vendors.
However it sounded you like were going to cannibalise the cables you bought elsewhere to try to make them work; so without knowing your level of skill, the luck may be needed – hirose connectors are a pain!
Note that many (no idea if all) of the knockoffs use 17mm TRS connectors. The ones I sent above have all de facto standardised on 14mm.
An yes hirose are a PITA but the chicom accessories and the micro use mini phone plugs only a little different, I re-pined/wired cables for my KVL3K, somewhere I have the pin outs for all the cables I need.
