Scanner_Rider
I don't know if the rural PDs have a repeater capable channel 2 like the S.O one number above TGID to reduce traffic saturation or a non repeater local private talk group TGID like the VFD uses beside the 10 tac channels.
I have tried for a couple weeks running TGID discovery on my scanner after tried adding one digit up and down from the RPD TGID with no result either way, but being in a lowe signal area, it may just not be catching it if it is a repeater access channel. I'm reluctant to keep trying to use the TGID discovery because from what I have read about my scanner, extended search use may wear out the SD card memory.
