Hater PD565 Firmware Update Procedure
RichardDay
Hi,
I'm trying to update the firmware on a PD565. Having switched the cable to 'DL' and connected the radio, the update package still doesn't show any available USB port.
Reading online, I came across some instructions for another PD series radio saying that it has to be put into update mode by powering on with the PTT and 'top orange button' held down - but the 565 doesn't have a top button!
I've tried various other key combinations to no avail. Is anyone able to advise how to enable update mode on this radio?
Many thanks,
Rich
Usually the no port found error is from the PC/cable and does not have anything to do with the radio.
I have problems with programming cables going offline right after a read or maybe 2 or 3 writes/clones.
I try putting the cable in a different port and that usually works but sometimes i have to log off and on to get the cable to be recognized.
Someday this will happen when I have time to look at the usb port properties and see if I find any errors.
If there is no power on button sequence listed the DL position is supposed to be all you need.
RichardDay
Thanks for the info!
I've had no problems with programming - it's only the firmware update that is causing issues. I've tried multiple ports and reboots, without success. Have now arranged to borrow another PC to eliminate any USB controller / software compatibility issues.
P.S. Autocorrect did indeed reflect my feelings at the time. I don't think I can edit the post title now though!
RichardDay
Just to update in case it helps anyone else...
I tried a different PC, initially with the same result, so I went back to trying various power on key combinations. PTT + SK1 put it into update mode (blank screen and flashing red LED), and the firmware update was successful. Not sure why it didn't work the first time, as that was the first key combination I tried!
