Hatzolah ems nyc
ICP114
Anyone have the tones from the quick call s that go out so i dont have to monitor the entire nyc system
The B,F, OR THE Q
SCANdal
Silent Key
Hudson Valley, NY
Tones? What tones?
114,
Are you asking about Boro Park, Flatbush, or Queens on 160.280 or some other groups on an altogether different frequency?
SCANdal
bezking
On the Road
I am pretty sure they don't use QCII tones, I have seen them using MDC-1200 selcalls though...
dovy6
I apologize for the late post. I believe that H uses MDC - 1200 for signaling. I am in the process of attempting to get the MDC info from a friend. If / when I get it I will post it here :)
dovy6
OK, here is the info I got:
B Boro Park 130
C Catskils 038
CH Crown Heights 230
ES East Side 330
F Flatbush 430
K Canarsie 530
M Manhattan 034
Q Queens 630
RD Riverdale 036
RL Rockaway Lawrence 730
SG Seagate 037
SI Staten Island 035
W Williamsburg 830
WS West Side 033
Y Washington Heights 930
Enjoy!
SCANdal
Silent Key
Hudson Valley, NY
All the middle numbers being "3" is unusual too
6,
So all the members of a particular group, say West Side, when they key up are sending 033 after (or before, I haven't listened in a while) their voice message? There's no way to distingush an individual member? With all the possible combinations MDC1200 offers, I find that interesting.
SCANdal
dovy6
OK. I believe the way it works is that each member has a 4 digit ID. The radios are programmed with multiple channels. For instance, channel one is "open", just 160.280 pl 167.9 and no MDC. You'll hear everything the base transmits, and anything said close enough for your radio to pick up. Channel 2 would be 160.200, the "talk about" channel. Channel 3 might be "F group", for flatbush group, in which your radio is muted until and unless it hears the 3 digit "group number", in this case 430, after which it unmutes. So if the base had a call on Ocean Parkway and Avenue T, the base would tx a 430, opening that group, and then say "any units available Ocean Parkway and T, patient not feeling well" or whatever the call is.....
Channel 4 may be "private", in which the radio is muted until it hears that unit's ID. So if that member had his radio with the ID of 5252 or whatever, it would be silent unless the base transmitted an MDC 5252 to "open" his radio. This is useful when the member wants to get some sleep, for instance.
Obviously this is just an example.
Dovy
dovy6
Well each member's radio does send an ID as well, but mostly the MDC is used to get groups so members from (say) Flatbush dont have to hear all the calls in the other neighborhoods...
zerg901
If you go to Google and enter MDC 1200 you will get lots of good hits - Wikipdia - BatLabs - radioreference
If you are asking about the basic science - IIRC the basic idea is >>>>> if you add Wave 1 to Wave 2 you get Wave 3 which is the sum of Wave 1 plus Wave 2
Try searching for info on resonance or resonant circuits
Selective calling - Wikipedia, the free encyclopedia has some info
avi123
Pike Co PA
NYC Hatzolah MDC codes
Here’s what I found. Hatzolah as a whole is using CAD with their radios so all units can be on a central
frequency and as they are needed their 3 digit identifier code is broadcasted so they will only hear the
calls related to their area only. I found PL’s but unknown if they work. You will have to test them when
you go there.
NYC Primary H-Base 160.2800 (167.4) Tac 160.3000 (167.4)
MDC Tone Radio System(CAD)
B – Boro Park 130 RD – Riverdale 036
C – Catskills 038 RL – Rockaway Lawrence 730
CH – Crown Heights 230 SG – Seagate 037
ED – East Side 330 SI – Staten Island 035
F – Flatbush 430 W – Williamsburg 830
K – Canarsie 530 WS – Westside 033
M – Manhattan 034 Y – Washington Heights 930
Q – Queens 630
Orange/Sullivan Counties, NY (Catskills) 160.2800 (CSQ)
Monsey (B) 151.9250 (PL??) (M) 160.1400 (PL??)
New Square (B) 159.8850 (D 074) (M) 160.9350 (PL??)
