Having Trouble with Ontario Fleetnet APCO Tracking w/PRO96
elyps
Toronto
Thanks in advance for any help on this--I've had a PRO 96 scanner for the last 6 weeks and have programmed single and multiple control channels for my local sites, i.e. Edgar, Penetang...with the proper talkgroups loaded and running my bank as "closed." I receive nothing. The only way I receive anything is to load the whole list of all talk channels as FM, NOT Motorola...and then I get all the analog and digital talkgroups active on the local channels.
Does anybody perhaps have a detailed list of how to program this from the keypad or a WIN96 file that I can load...I'm trying to isolate Collingwood 534, Barrie 533, and Huronia West 536 talkgroups for OPP and eliminate everything else.
scnnr
Manitoba, Canada
Make sure that you are set for MO
http://support.radioshack.com/support_tutorials/communications/200-0526/pro96_tut-c.htm
Then you need ot make sure that you are set up as the others said.
SET FOR OFFSET SPACING AND TABLE
WHILE SCANNING BANK YOU HAVE SET FOR TRUNKING SAY BANK 1 HIT
PGM> TRUNK
FUNC > 2 AND TYPE IN
141.01500 & ENTER
NEXT TYPE IN
380 & ENTER
FOR THE STEP SIZES USE THE ARROW KEYS TO FIND THE ONE THAT YOU NEED
15.00 & PRESS ENTER
NEXT YOU WOULD HIT THE FUNC 3 BUTTON AND
USE THE UP- DOWN ARROW KEYS TO FIND TABLE AND PRESS ENTER. YOU ARE SET TO GO.
elyps
Toronto
thanks for the info...now working fine
I appreciate the all of the fast 8) replies to my post--everything was fine within 10 minutes of reconfiguring the pro96.
