Havis console internal speaker mounting
Anderegg
Enter text in this field
San Diego
Preparing a Havis 24" vehicle specific console for a 2021 Interceptor Utility. The console has mounting holes and grills on each side for installing dissasembled Motorola type speakers internally. My question is would I want to retain the back housing of the speaker inside the console rather than have the speaker cone "free floating"? The Havis instructions give no indication as to how to perform this other than specifying a nut and bolt length.
Paul Anderegg
kb4mdz
Cary, NC
If you have room, retain the back of the speaker. That'll protect the cone and the connections.
Yes, as well as providing proper sound; back pressure from the rear side of the housing is important for proper operation. If you just let the back side of the speaker cone fill the console's internal space it will sound bad. I can't quote theory, but I know that I have seen it/heard it.
kb5udf
Louisiana
Running a speaker driver/cone in a large box begins to approximate no box at all. Unless the driver is rated as "infinite baffle" or "free air" consequences can include distorted sound and/or premature failure (due to over-excursion) when the volume is cranked to over-come road noise. There is a whole set of parameters (Thiel/Small) that describe a speaker driver's characteristics including suitable enclosures.
In summary, doing surgery on a well engineered (speaker) to put the driver in random hole/box is not a great idea. I'd keep the speaker as is, and modify the console hole if practical. Keep the driver/cone in its enclosure/box, then it doesn't matter much if you put it in the console.
kb5udf
Louisiana
Delete term "infinite baffle," a very large box is free air approximate, not IB
Anderegg
San Diego
OK, console finally arrived and I took apart a speaker and well...I don't see any point in keeping the rear housing attached...right?
Anderegg
San Diego
On a related note, how will housingless cone in the side of the console affect the tone of the audio? The APX has bass mid and treble controls, but for the Uniden SDS on speaker two, I had to install a capacitor to reduce the bass present when being used with a standard 8 ohm Motorola housed stand alone speaker. Wondering if I need to retain or remove that...maybe no housing means less bass?
Psulk
